Helper Tool for High Precision Mask Cutting
Started by Bob S, Tue 10/06/15 06:49 PM
Blaine J
I think the color choices are black or red, and Askew-Taylor carries black.
Bob,
Do you know if these pens come in white or yellow color?
Regards
MICROPERM Pens: Outstanding for marking on any surface, this pen is perfect for marking your masking lines on a windscreen or canopy when a pre-cut mask is not provided...
Once you cover your canopy with masking film, the marked lines clearly show through, so your blade cuts will be as accurate as the lines you marked.
After removing the masking film, any left-over marker residue on the canopy will remove easily with alcohol and a microbrush or swab – just try to avoid your painted areas with the alcohol if you used acrylics.
I've had the best results making dotted lines instead of solid, plus, there's less to clean up at the end of the process!
For the masking process, I use the .01 pen..............for "opening" vents on my bodies, I use the .03 version.
Available at Askew-Taylor Paints 110 Glenwood Ave in downtown Raleigh. (Please see my review of this fantastic store in the General Discussion forum)
