Grand Sport Corvette
Started by Bob S, Wed 03/30/16 06:59 PM
In 1962 Corvette chief engineer Zora Arkus-Duntov initiated a program to produce a lightweight version based on the new 1963 Corvette. Concerned about Ford and what they were doing with the Shelby Cobra, Duntov's program included plans to build 125 Grand Sport Corvettes to make them eligible for international Grand Touring races. After the GM executives learned of the secret project, the program was stopped, and only five cars were built. All five cars have survived and are in private collections. They are among the most coveted and valuable Corvettes ever built.
The cars were driven by famed contemporary race drivers such as Roger Penske, A.J. Foyt, Jim Hall, and Dick Guldstrand among others. Dick Thompson was the first driver to win a race in the Grand Sport. He won a 1963 Sports Car Club of America race at Watkins Glen on August 24, 1963 driving Grand Sport 004.
Chassis #2 is a part of the permanent collection at the Simeone Foundation Automotive Museum in Philadelphia, PA, USA. The car is in running condition, and is the only Grand Sport which is original and unrestored. Also on display are a replica body and a spare 377 cubic inch engine, which were commissioned by the car's previous owner, Jim Jaeger, for participation in vintage racing without damaging the original components.
The Corvette Grand Sports were raced with several different engines, but the most serious factory engine actually used was a 377 cubic inch displacement, all-aluminum, small block with four Weber side-draft carburetors and a cross-ram intake, rated 550 hp (410 kW) at 6400 rpm. Body panels were made of thinner fiberglass to reduce weight and the inner body structure 'birdcage' was aluminum rather than steel. The ladder-type frame utilized large seamless steel tubular side members connected front and rear with crossmembers of about the same diameter tubes. Another crossmember was just aft of the transmission and a fourth one at the rear kick-up anchored the integral roll cage. The frame was slightly stiffer than the 1963 Corvette production frame and was 94 pounds lighter. A number of other lightweight components were utilized to reduce overall weight to about 800 pounds less that the production coupe.
This is Accurate Miniatures 1/25 scale version of what looks to be either chassis #3, or chassis #5. I had the decals to build the car as it was driven by Bob Bondurant, which would have been chassis #3, I think.
For the body, I used Tamiya Racing Blue Metallic on a base of medium gray, and polished it up with Novus #2 and #1, with a final coat of Tamiya clear. The upholstery and door panels are Model Master Nassau Blue Metallic auto lacquer. Some of the decal stripes were missing from my eBay purchase, so they were made from sign shop vinyl film, the windshield surround was painted w/ Testors Rubber enamel, the wheels were painted with an equal mix of silver and gold. Bare Metal Foil was used for the oiler cover hinge and hood pins. In the engine bay, those sweet Weber carbs were painted Testors Pure Gold, the engine block is Silver Leaf, and the trumpets are Krylon Satin Nickel finished. Plug wires were made from .01 bead wire and plug boots are from Detail Master, Oil and water lines are made from parts box hollow rubber tubing. The hood was fairly complex, since it involved some construction of a series of P/E brass vent fins to be assembled on a rickety frame -- I messed with 'em and cussed right much - but they came out fine.
This is a beauty of a kit, and the instructions are very detailed and even include pictures of the real engine. I wish Accurate Miniatures was still around - I'd thank them myself for the love they put into their model kits!
