Aston Martin 2005 Le Mans
Started by Bob S, Sun 10/04/15 05:40 PM
OK - thank you Ryan - hope to meet you soon!
Agree with Ron that is outstanding and can't wait to see it person.
Bob, yes resin subjects are allowed. Best I can recall we don't have any restrictions on the medium used. Post away.
Appreciate the comment Ron - I'm assuming that resin subjects are allowed here, right? Correct me if I've blundered...
That looks outstanding! Can't wait to see it.
This is a 1/24 scale resin kit from Model Factory Hiro -- these kits are pricey, but the reward is in the build!  For resin, I soak the parts in a heavy-duty degreaser for an hour or so, then rinse under hot water, then scrub with a soft tooth brush and toothpaste, and a last hot rinse, and allow to air dry.
MFH has given you everything you need in these outstanding kits: super-clean accurate resin body and parts, highly machined rims and P/E, real rubber,
crystal clear vac-formed windscreens, and thin, opaque decals to rival Cartograf. All I had to do was add paint, glue and bench time.
